Removal Instructies
DDS - Infospyware.
DDS zal 2 logfiles openen:
* DDS.txt
* Attach.txt
Technische details
HijackThis
Running processes:Register
C:\Documents and Settings\Administrator\Application Data\Protector-rfd.exe
O4 - HKCU\..\Run: [Inspector] C:\Documents and Settings\Administrator\Application Data\Protector-rfd.exe
"Inspector"="C:\Documents and Settings\Administrator\Application Data\Protector-rfd.exe"
"Debugger"="svchost.exe"
C:\Documents and Settings\Administrator\Desktop\Windows Custodian Utility.lnk
C:\Documents and Settings\Administrator\Start Menu\Programs\Windows Custodian Utility.lnk
