63
Het Speccy rapport heeft een vreemde opmaak en is onvolledig.
We kijken met een andere tool.
Download WhoCrashed naar je bureaublad.
Dubbelklik op "whocrashedSetup.exe" om het programma te installeren.
Nadat 'WhoCrashed' is geïnstalleerd en opgestart, klik op de knop Analyze.
Na de analyse, kopieer en plak de gehele inhoud van het venster "Report" als bijlage in je volgende bericht.
64
[font=Segoe UI, Arial]Computer name: EIGENAAR-PC
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:\Windows
Hardware: Aspire E300, Acer , F80M-2
CPU: AuthenticAMD AMD Athlon(tm) 64 Processor 3200+ AMD586, level: 15
1 logical processors, active mask: 1
RAM: 2147016704 bytes total
[/font]
Crash Dump Analysis
[font=Segoe UI, Arial]Crash dump directory: C:\Windows\Minidump[/font]
[font=Segoe UI, Arial]Crash dumps are disabled for your computer.
[/font]
[font=Segoe UI, Arial]No valid crash dumps have been found on your computer[/font]
Conclusion
[font=Segoe UI, Arial]Crash dumps are not enabled on this computer which explains why there are no crash dumps available. It is suggested you enable crash dumps on your computer. Use the System applet in Control Panel. Click the Advanced tab, then click the Startup and Recovery button. Select one of the options from the drop-down list in the Write Debugging Information box.
For more information refer to the following article: Enabling crash dumps on your computer.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further. [/font]
[/font]
Crash Dump Analysis
[/font]
Conclusion
65
en hier nogeens van die ene deed ernu langer over om te analyseren nl de vorige x was ie zo klaar
http://speccy.piriform.com/results/k2Uv ... 4tUthep6yN
66
Het Speccy rapport is nu wel in orde.
Schakel systeem crashdumps in:
- Klik op Start - Configuratiescherm - Systeem
- Klik op Geavanceerde systeeminstellingen
- Open het tabblad Geavanceerd en klik op de knop Instellingen in het kader Opstart- en herstelinstellingen
- Neem de volgende instellingen over:
- Herstart hierna de computer.
67
yep hing zicg weer op na herstart heb die dump gedaan maar wat ik kan zien is er niks
Crash Dump Analysis
[font=Segoe UI, Arial]Crash dumps are enabled on your computer.
[/font]
Conclusion
[font=Segoe UI, Arial]Crash dumps are enabled but no valid crash dumps have been found. In case you are experiencing system crashes, it may be that crash dumps are prevented from being written out. Check out the following article for possible causes: If crash dumps are not written out.
Crash Dump Analysis
[/font]
Conclusion
68
We kijken verder.
Download MiniToolBox en plaats deze tool op je bureaublad.
Let op: Sluit nu eerst alle openstaande programma's en webbrowsers!
Rechtsklik op "MiniToolBox" en klik op "Als Administrator uitvoeren".
Een programma is blijkbaar niet gecrasht, een andere mogelijkheid is dat je systeem tijdelijk overbelast is.yep hing zicg weer op na herstart heb die dump gedaan maar wat ik kan zien is er niks
We kijken verder.
- Flush DNS
- Report IE Proxy Settings
- Reset IE Proxy Settings
- Report FF Proxy Settings
- Reset FF Proxy Settings
- List content of Hosts
- List IP configuration
- List Winsock Entries
- List last 10 Event Viewer Errors
- List Installed Programs
- List Devices (Only Problems)
- List Users, Partitions and Memory size
- List Minidump Files
- List Restore Points
71
ff een vraag kan ik deze progammas verwijderen ik gebruik alleen nl outlook excel en wordt van microsoft
Microsoft Visual C ++ 2008 Restributable - x 64 9.0.3 staat er 4 x
Microsoft Visual C ++ 2010 Restributable - x 64 10.0 staat er 2 x
Microsoft Visual C ++ 2011 Restributable - x 64 11.0 staat er 2 x
Microsoft Visual C ++ 2012 Restributable - x 64 12.0 staat er 1 x
staat nog meer in
staat nog meer in
72
Het programma McTkSchedulerService.exe geeft regelmatig een foutmelding. Het wordt echter niet in de softwarelijst weergegeven.
Dat kan je beter niet doen, deze zijn nodig voor bepaalde programma's.ff een vraag kan ik deze progammas verwijderen...
- AppCleaner
- Druk op de knop Fixen.
74
Download SystemLook en bewaar het op je bureaublad.
32-bit: SystemLook.exe of SystemLook.exe.
Het script heeft ook niets verwijdert, alleen informatie opgevraagd.ben mss wat voorbarig maar hij hangt nog steeds
:filefind
:folderfind
TrueKey
:regfind
Intel Security True Key Scheduler
