Jac-Lin
AV: Norton
AM: Norton
Wifi valt steeds uit
zo 21 okt, 2018 19:27:36
Hallo, Onze wifi verbinding vaalt tot grote ergernis met regelmaat uit. Op advies van een collega heb ik bij de netwerkkaart het vinkje weggehaald die aangeeft dat de kaart mag worden uitgeschakeld. Kan iemand kijken naar mijn log of er nog meer mis is en wat ik dan moet veranderen want ik wordt er knettergek van.
alvast bedankt Gr Jac-Lin
MiniToolBox by Farbar  Version: 17-06-2016
Ran by t3-bi (administrator) on 21-10-2018 at 19:19:42
Running from "C:\Users\t3-bi\Downloads"
Microsoft Windows 10 Home  (X64)
Model: Easynote ENTE70BH Manufacturer: Packard Bell
Boot Mode: Normal
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
========================= FF Proxy Settings: ==============================
========================= IP Configuration: ================================
Broadcom 802.11n Network Adapter = Wi-Fi (Connected)
Realtek PCIe GBE Family Controller = Ethernet (Media disconnected)
TAP-Windows Adapter V9 = Ethernet 4 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 11" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 12" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 5" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Windows IP Configuration
   Host Name . . . . . . . . . . . . : LAPTOP-M24H9J6M
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 30-65-EC-9E-B4-DE
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter LAN-verbinding* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
   Physical Address. . . . . . . . . : CA-FF-28-76-A7-95
Wireless LAN adapter LAN-verbinding* 5:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
   Physical Address. . . . . . . . . : CA-FF-28-76-AF-95
Ethernet adapter Ethernet 4:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-06-AE-58-0E
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : Broadcom 802.11n Network Adapter
   Physical Address. . . . . . . . . : 52-50-87-54-99-17
   Link-local IPv6 Address . . . . . : fe80::353a:5515:2ee1:c9dc%22(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.178.101(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : zondag 21 oktober 2018 17:13:28
   Lease Expires . . . . . . . . . . : zondag 21 oktober 2018 20:00:50
   Default Gateway . . . . . . . . . : 192.168.178.1
   DHCP Server . . . . . . . . . . . : 192.168.178.1
   DHCPv6 IAID . . . . . . . . . . . : 164167464
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-8A-6B-1B-30-65-EC-9E-B4-DE
   DNS Servers . . . . . . . . . . . : 84.116.46.22
                                       84.116.46.23
   NetBIOS over Tcpip. . . . . . . . : Enabled
DNS request timed out.
    timeout was 2 seconds.
Server:  UnKnown
Address:  84.116.46.22
Addresses:  2a00:1450:400e:809::200e
      172.217.17.46
Pinging google.com [172.217.17.46] with 32 bytes of data:
Reply from 172.217.17.46: bytes=32 time=19ms TTL=54
Reply from 172.217.17.46: bytes=32 time=17ms TTL=54
Ping statistics for 172.217.17.46:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 17ms, Maximum = 19ms, Average = 18ms
Server:  UnKnown
Addresses:  2001:4998:58:1836::10
      2001:4998:44:41d::3
      2001:4998:44:41d::4
      2001:4998:c:1023::5
      2001:4998:58:1836::11
      2001:4998:c:1023::4
      98.138.219.231
      72.30.35.9
      98.137.246.7
      72.30.35.10
      98.138.219.232
      98.137.246.8
Pinging yahoo.com [98.137.246.7] with 32 bytes of data:
Reply from 98.137.246.7: bytes=32 time=165ms TTL=48
Reply from 98.137.246.7: bytes=32 time=158ms TTL=48
Ping statistics for 98.137.246.7:
    Minimum = 158ms, Maximum = 165ms, Average = 161ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
 13...30 65 ec 9e b4 de ......Realtek PCIe GBE Family Controller
 18...ca ff 28 76 a7 95 ......Microsoft Wi-Fi Direct Virtual Adapter #4
 21...ca ff 28 76 af 95 ......Microsoft Wi-Fi Direct Virtual Adapter #5
  2...00 ff 06 ae 58 0e ......TAP-Windows Adapter V9
 22...52 50 87 54 99 17 ......Broadcom 802.11n Network Adapter
  1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0    192.168.178.1  192.168.178.101     55
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
    192.168.178.0    255.255.255.0         On-link   192.168.178.101    311
  192.168.178.101  255.255.255.255         On-link   192.168.178.101    311
  192.168.178.255  255.255.255.255         On-link   192.168.178.101    311
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link   192.168.178.101    311
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link   192.168.178.101    311
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    331 ::1/128                  On-link
 22    311 fe80::/64                On-link
 22    311 fe80::353a:5515:2ee1:c9dc/128
                                    On-link
  1    331 ff00::/8                 On-link
 22    311 ff00::/8                 On-link
Persistent Routes:
  None
========================= Winsock entries =====================================
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [64000] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (10/21/2018 06:38:00 PM) (Source: Microsoft-Windows-SpellChecker) (User: LAPTOP-M24H9J6M)
Description: brave hendrikbrave hendrik-2147467263
Error: (10/21/2018 06:37:47 PM) (Source: Microsoft-Windows-SpellChecker) (User: LAPTOP-M24H9J6M)
Error: (10/21/2018 10:25:53 AM) (Source: Office 2016 Licensing Service) (User: )
Description: Subscription licensing service failed: -1073422333
Error: (10/20/2018 04:30:38 PM) (Source: Office 2016 Licensing Service) (User: )
Error: (10/20/2018 04:27:19 PM) (Source: Microsoft Office 16) (User: )
Description: Microsoft Outlook: Rejected Safe Mode action : Outlook is de vorige keer niet gestart. In de veilige modus kunt u proberen het probleem op te lossen, maar diverse functies zijn mogelijk niet beschikbaar in deze modus.
Wilt u de veilige modus starten?.
Rejected Safe Mode action : Microsoft Outlook.
Error: (10/19/2018 09:10:36 AM) (Source: Office 2016 Licensing Service) (User: )
Error: (10/18/2018 01:12:41 PM) (Source: Office 2016 Licensing Service) (User: )
Error: (10/17/2018 10:45:20 AM) (Source: Microsoft Office 16) (User: )
Error: (10/17/2018 10:32:43 AM) (Source: Application Hang) (User: )
Description: Het programma OUTLOOK.EXE, versie 16.0.10827.20150 reageert niet meer op Windows en is afgesloten. Als u wilt zien of er meer informatie over het probleem beschikbaar is, raadpleegt u de probleemgeschiedenis in het onderdeel Beveiliging en onderhoud van het Configuratiescherm.
Proces-id: 1a54
Starttijd: 01d465ea9adc9423
Eindtijd: 118
Toepassingspad: C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXE
Rapport-id: a059f13d-c49e-4d54-9f07-01d1d504b40b
Volledige pakketnaam met fout:
Relatieve toepassings-id van pakket met fout:
Error: (10/17/2018 09:10:51 AM) (Source: Office 2016 Licensing Service) (User: )
System errors:
Error: (10/21/2018 02:45:14 PM) (Source: DCOM) (User: LAPTOP-M24H9J6M)
Description: toepassingsspecifiekLokaalActiveren{8BC3F05E-D86B-11D0-A075-00C04FB68820}{8BC3F05E-D86B-11D0-A075-00C04FB68820}LAPTOP-M24H9J6Mt3-biS-1-5-21-2763049548-344983973-2474456283-1001LocalHost (via LRPC)Microsoft.Windows.ContentDeliveryManager_10.0.17134.1_neutral_neutral_cw5n1h2txyewyS-1-15-2-350187224-1905355452-1037786396-3028148496-2624191407-3283318427-1255436723
Error: (10/21/2018 12:10:36 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalActiveren{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (10/21/2018 10:25:13 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/21/2018 10:22:18 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/20/2018 05:02:00 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/20/2018 04:28:43 PM) (Source: DCOM) (User: LAPTOP-M24H9J6M)
Error: (10/20/2018 04:28:40 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/20/2018 04:28:31 PM) (Source: DCOM) (User: LAPTOP-M24H9J6M)
Error: (10/20/2018 04:24:58 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/19/2018 09:36:29 PM) (Source: DCOM) (User: NT AUTHORITY)
Microsoft Office Sessions:
Error: (10/21/2018 06:38:00 PM) (Source: Microsoft-Windows-SpellChecker)(User: LAPTOP-M24H9J6M)
Error: (10/21/2018 06:37:47 PM) (Source: Microsoft-Windows-SpellChecker)(User: LAPTOP-M24H9J6M)
Error: (10/21/2018 10:25:53 AM) (Source: Office 2016 Licensing Service)(User: )
Error: (10/20/2018 04:30:38 PM) (Source: Office 2016 Licensing Service)(User: )
Error: (10/20/2018 04:27:19 PM) (Source: Microsoft Office 16)(User: )
Description: Microsoft OutlookOutlook is de vorige keer niet gestart. In de veilige modus kunt u proberen het probleem op te lossen, maar diverse functies zijn mogelijk niet beschikbaar in deze modus.
Error: (10/19/2018 09:10:36 AM) (Source: Office 2016 Licensing Service)(User: )
Error: (10/18/2018 01:12:41 PM) (Source: Office 2016 Licensing Service)(User: )
Error: (10/17/2018 10:45:20 AM) (Source: Microsoft Office 16)(User: )
Error: (10/17/2018 10:32:43 AM) (Source: Application Hang)(User: )
Description: OUTLOOK.EXE16.0.10827.201501a5401d465ea9adc9423118C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXEa059f13d-c49e-4d54-9f07-01d1d504b40b
Error: (10/17/2018 09:10:51 AM) (Source: Office 2016 Licensing Service)(User: )
CodeIntegrity Errors:
  Date: 2018-06-12 08:27:45.094
  Description: Code Integrity determined that a process (\Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\chrome.exe) attempted to load \Device\HarddiskVolume3\Program Files\Norton Security\NortonData\22.9.3.13\Definitions\IPSDefs\20180611.061\IPSEng64.dll that did not meet the Microsoft signing level requirements.
  Date: 2018-06-09 12:06:30.016
  Description: Code Integrity determined that a process (\Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\chrome.exe) attempted to load \Device\HarddiskVolume3\Program Files\Norton Security\NortonData\22.9.3.13\Definitions\IPSDefs\20180608.061\IPSEng64.dll that did not meet the Microsoft signing level requirements.
=========================== Installed Programs ============================
Avanquest Message (HKCU\...\{20573C69-4A68-4BEF-A23D-365CB66924CE}) (Version: 2.08.0 - Avanquest Software)
Broadcom 802.11 Network Adapter (HKLM\...\Broadcom 802.11 Network Adapter) (Version: 7.35.303.0 - Broadcom Corporation)
Broadcom Bluetooth Drivers (HKLM\...\{0A1B4690-E176-4533-8058-939480AEE1D0}) (Version: 12.0.1.710 - Broadcom Corporation)
inPixio Photo Clip 8 (HKLM-x32\...\{65634D2B-B6D1-4B35-B4C9-F3999B8D008B}) (Version: 8.5.0 - InPixio)
Intel(R) Chipset Device Software (HKLM-x32\...\{fb610cea-ba50-4d4b-a717-cf025419035c}) (Version: 10.1.1.13 - Intel(R) Corporation) Hidden
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.0.0.1156 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4703 - Intel Corporation)
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 1.1.253.0 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{4B230374-6475-4A73-BA6E-41015E9C5013}) (Version: 1.0.0.532 - Intel Corporation)
Java 8 Update 111 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F64180111F0}) (Version: 8.0.1110.14 - Oracle Corporation)
Microsoft Office 365 - nl-nl (HKLM\...\O365HomePremRetail - nl-nl) (Version: 16.0.10827.20181 - Microsoft Corporation)
Microsoft Office Configuration Analyzer Tool 2.2 (HKLM-x32\...\{EA5C0F11-00CA-0321-0801-141002021782}) (Version: 2.2.6018.801 - Microsoft Corporation)
Microsoft Ondersteunings- en herstelassistent voor Office 365 (HKCU\...\4415f693b586d348) (Version: 16.0.1799.1 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.3.7294.0108 - Microsoft Corporation)
Microsoft Visual C++ 2010  x64 Redistributable - 10.0.30319 (HKLM\...\{DA5E371C-6333-3D8A-93A4-6FD5B20BCC6E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2010  x86 Redistributable - 10.0.30319 (HKLM-x32\...\{196BB40D-1578-3D01-B289-BEFC77A11A1E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2013 Preview Redistributable (x64) - 12.0.20617 (HKLM-x32\...\{448652c1-f5f3-4230-98c6-68c10c88b1fb}) (Version: 12.0.20617.1 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.14.26429 (HKLM-x32\...\{2019b6a0-8533-4a04-ac0e-b2c10bdb9841}) (Version: 14.14.26429.4 - Microsoft Corporation)
Mozilla Firefox 62.0.3 (x64 nl) (HKLM\...\Mozilla Firefox 62.0.3 (x64 nl)) (Version: 62.0.3 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 60.0.2 - Mozilla)
Norton Security (HKLM-x32\...\NGC) (Version: 22.15.1.8 - Symantec Corporation)
Norton WiFi Privacy (HKLM-x32\...\Norton WiFi Privacy) (Version: 1.4.9 - Symantec Corporation)
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.10827.20181 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.10827.20181 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0413-1000-0000000FF1CE}) (Version: 16.0.10827.20181 - Microsoft Corporation) Hidden
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.3.723.2015 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7904 - Realtek Semiconductor Corp.)
Samsung USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.5.61.0 - Samsung Electronics Co., Ltd.)
Smart Switch (HKLM-x32\...\{74FA5314-85C8-4E2A-907D-D9ECCCB770A7}) (Version: 4.1.16104.4 - Samsung Electronics Co., Ltd.) Hidden
Smart Switch (HKLM-x32\...\InstallShield_{74FA5314-85C8-4E2A-907D-D9ECCCB770A7}) (Version: 4.1.16104.4 - Samsung Electronics Co., Ltd.)
TomTom MyDrive Connect 4.2.0.3437 (HKLM-x32\...\MyDriveConnect) (Version: 4.2.0.3437 - TomTom)
Update for Windows 10 for x64-based Systems (KB4023057) (HKLM\...\{17515373-7495-4995-9089-B7D6DF455C38}) (Version: 2.6.0.0 - Microsoft Corporation)
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2012 x86 Redistributables (HKLM-x32\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
Visual Studio C++ 10.0 Runtime (HKLM-x32\...\{4412F224-3849-4461-A3E9-DEEF8D252790}) (Version: 10.0.0 - TomTom International B.V.)
WinRAR 5.20 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.20.0 - win.rar GmbH)
========================= Devices: ================================
**** End of log ****
Het is beter om vergiffenis te vragen dan om toestemming.
Black Tiger
Moderator (Netwerken)
OS: Win7/Linux
AV: Emsisoft Antimalware
AM: Malware Bytes
Re: Wifi valt steeds uit
zo 21 okt, 2018 21:15:38
Ik moet nog even nader kijken, heb even heel vluchtig gekeken. Vannacht of morgen heb ik meer tijd om het beter te bekijken.
Waar ik zou mee beginnen is sowieso het volgende (ongeacht of ik wel of niet beter ga kijken straks).
1.) Norton security deinstalleren (evt. tijdelijk)
2.) Norton wifi privacy deinstalleren. (evt. tijdelijk)
3.) Zorg ter vervanging van deze dat Windows defender volledig draait, alles groen is en dus ook de Windows Firewall actief is.
4.) Gebruik je snel opstarten van Windows 10, schakel dit uit
5.) Schakel ipv6 uit
6.) Update je Java naar de nieuwste versie, oudere versies zijn onbetrouwbaar en vaak lek.
7.) Doe het volgende eens:
