gerrieger
OS: windows10
AV: norton
ip configuratie ongeldig
za 17 nov, 2018 20:00:06
heel regelmatig is mijn internetverbinding verbroken, krijg de melding: LAN verbinding heeft geen geldige IP configuratie
via de minitoolbox heb ik een diagnose laten maken, zie onderstaand rapport.
Wie o wie zou mij kunnen adviseren?  bij voorbaat hartelijk dank.
MiniToolBox by Farbar  Version: 17-06-2016
Ran by Ger (administrator) on 17-11-2018 at 19:44:55
Running from "C:\Users\Ger\Downloads"
Microsoft Windows 10 Home  (X64)
Model: 260-a132nd Manufacturer: HP
Boot Mode: Normal
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
========================= Hosts content: =================================
========================= IP Configuration: ================================
Realtek PCIe GBE Family Controller = Ethernet (Connected)
Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter = Wi-Fi (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="LAN-verbinding* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 14" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth-netwerkverbinding" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 15" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 16" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-OR2Q5LH
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : C8-D3-FF-38-01-B3
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : 2a02:f6f:1f8:0:7d91:179a:bd34:6f1a(Preferred)
   Lease Obtained. . . . . . . . . . : zaterdag 17 november 2018 14:28:28
   Lease Expires . . . . . . . . . . : zaterdag 17 november 2018 20:33:39
   IPv6 Address. . . . . . . . . . . : 2a02:f6f:1f8:0:ddd1:ff08:6b0e:fcda(Preferred)
   IPv6 Address. . . . . . . . . . . : fdaa:bbcc:ddee:0:ddd1:ff08:6b0e:fcda(Preferred)
   Temporary IPv6 Address. . . . . . : 2a02:f6f:1f8:0:90a1:2410:7c15:48c3(Preferred)
   Temporary IPv6 Address. . . . . . : fdaa:bbcc:ddee:0:90a1:2410:7c15:48c3(Preferred)
   Link-local IPv6 Address . . . . . : fe80::ddd1:ff08:6b0e:fcda%6(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.11.47(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : zaterdag 17 november 2018 14:28:26
   Lease Expires . . . . . . . . . . : zaterdag 17 november 2018 20:39:58
   Default Gateway . . . . . . . . . : fe80::2a9e:fcff:fe44:1ab%6
                                       192.168.11.1
   DHCP Server . . . . . . . . . . . : 192.168.11.1
   DHCPv6 IAID . . . . . . . . . . . : 166497973
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-58-46-E8-C8-D3-FF-38-01-B3
   DNS Servers . . . . . . . . . . . : 2a02:f68:0:6e:6e73::1
                                       2a02:f68:0:cf3:6e73::2
                                       62.238.255.69
                                       212.115.192.100
                                       212.115.192.193
   NetBIOS over Tcpip. . . . . . . . : Enabled
   Connection-specific DNS Suffix Search List :
                                       home
Wireless LAN adapter Wi-Fi:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter
   Physical Address. . . . . . . . . : 3C-A0-67-B9-1A-05
Wireless LAN adapter LAN-verbinding* 15:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
   Physical Address. . . . . . . . . : 3E-A0-67-B9-1A-05
Wireless LAN adapter LAN-verbinding* 16:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #6
Server:  resolver1.zeelandnet.nl
Address:  2a02:f68:0:6e:6e73::1
Addresses:  2a00:1450:400e:80b::200e
  216.58.211.110
Pinging google.com [2a00:1450:400e:80b::200e] with 32 bytes of data:
Reply from 2a00:1450:400e:80b::200e: time=24ms
Reply from 2a00:1450:400e:80b::200e: time=23ms
Ping statistics for 2a00:1450:400e:80b::200e:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 23ms, Maximum = 24ms, Average = 23ms
Addresses:  2001:4998:c:1023::5
  2001:4998:c:1023::4
  2001:4998:44:41d::4
  2001:4998:44:41d::3
  2001:4998:58:1836::11
  2001:4998:58:1836::10
  98.137.246.8
  98.137.246.7
  98.138.219.232
  72.30.35.9
  98.138.219.231
  72.30.35.10
Pinging yahoo.com [2001:4998:c:1023::5] with 32 bytes of data:
Reply from 2001:4998:c:1023::5: time=156ms
Reply from 2001:4998:c:1023::5: time=154ms
Ping statistics for 2001:4998:c:1023::5:
    Minimum = 154ms, Maximum = 156ms, Average = 155ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
  6...c8 d3 ff 38 01 b3 ......Realtek PCIe GBE Family Controller
  4...3c a0 67 b9 1a 05 ......Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter
 30...3e a0 67 b9 1a 05 ......Microsoft Wi-Fi Direct Virtual Adapter #5
 41...3c a0 67 b9 1a 05 ......Microsoft Wi-Fi Direct Virtual Adapter #6
  1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0     192.168.11.1    192.168.11.47     25
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
     192.168.11.0    255.255.255.0         On-link     192.168.11.47    281
    192.168.11.47  255.255.255.255         On-link     192.168.11.47    281
   192.168.11.255  255.255.255.255         On-link     192.168.11.47    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link     192.168.11.47    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link     192.168.11.47    281
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  6    281 ::/0                     fe80::2a9e:fcff:fe44:1ab
  1    331 ::1/128                  On-link
  6    281 2a02:f6f:1f8::/64        On-link
  6    281 2a02:f6f:1f8::/64        fe80::2a9e:fcff:fe44:1ab
  6    281 2a02:f6f:1f8:0:7d91:179a:bd34:6f1a/128
                                    On-link
  6    281 2a02:f6f:1f8:0:90a1:2410:7c15:48c3/128
                                    On-link
  6    281 2a02:f6f:1f8:0:ddd1:ff08:6b0e:fcda/128
                                    On-link
  6    281 fdaa:bbcc:ddee:0:90a1:2410:7c15:48c3/128
                                    On-link
  6    281 fdaa:bbcc:ddee:0:ddd1:ff08:6b0e:fcda/128
                                    On-link
  6    281 fe80::/64                On-link
  6    281 fe80::/64                fe80::2a9e:fcff:fe44:1ab
  6    281 fe80::ddd1:ff08:6b0e:fcda/128
                                    On-link
  1    331 ff00::/8                 On-link
  6    281 ff00::/8                 On-link
Persistent Routes:
  None
========================= Winsock entries =====================================
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [64000] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (11/17/2018 02:40:04 PM) (Source: Perflib) (User: )
Description: WmiApRplC:\WINDOWS\system32\wbem\wmiaprpl.dll8
Error: (11/17/2018 02:40:03 PM) (Source: PerfNet) (User: )
Description:
Error: (11/17/2018 02:40:03 PM) (Source: Perflib) (User: )
Description: MSDTCC:\WINDOWS\system32\msdtcuiu.DLL8
Description: LsaC:\Windows\System32\Secur32.dll8
Description: ESENTC:\WINDOWS\system32\esentprf.dll8
Description: BITSC:\Windows\System32\bitsperf.dll8
Description: aspnet_stateC:\Windows\System32\aspnet_counters.dll8
Description: ASP.NET_4.0.30319C:\Windows\System32\aspnet_counters.dll8
Description: ASP.NETC:\Windows\System32\aspnet_counters.dll8
Error: (11/17/2018 02:27:04 PM) (Source: Perflib) (User: )
System errors:
Error: (11/17/2018 07:38:07 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Description: toepassingsspecifiekLokaalActiveren{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}DESKTOP-OR2Q5LHGerS-1-5-21-441301672-481600472-4131194173-1001LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (11/17/2018 02:46:29 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Description: {58598185-CF77-4407-B011-0C8282EF681F}
Error: (11/17/2018 02:27:53 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Error: (11/17/2018 01:51:16 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Error: (11/17/2018 01:50:04 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Error: (11/17/2018 01:38:56 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Error: (11/17/2018 01:12:04 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalStartenWindows.SecurityCenter.WscBrokerManagerNiet beschikbaarNT AUTHORITYSYSTEMS-1-5-18LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (11/17/2018 01:11:55 PM) (Source: DCOM) (User: DESKTOP-OR2Q5LH)
Description: Microsoft.MicrosoftEdge_42.17134.1.0_neutral__8wekyb3d8bbwe!ContentProcess#{00091402-0001-0000-8425-010000000000}
Error: (11/17/2018 01:11:20 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalActiveren{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Microsoft Office Sessions:
Error: (11/17/2018 02:40:04 PM) (Source: Perflib)(User: )
Error: (11/17/2018 02:40:03 PM) (Source: PerfNet)(User: )
Description:
Error: (11/17/2018 02:40:03 PM) (Source: Perflib)(User: )
Error: (11/17/2018 02:27:04 PM) (Source: Perflib)(User: )
========================= Devices: ================================
========================= Minidump Files ==================================
No minidump file found
**** End of log ****
Black Tiger
Moderator (Netwerken)
OS: Win7/Linux
AV: Emsisoft Antimalware
AM: Malware Bytes
Re: ip configuratie ongeldig
za 17 nov, 2018 20:18:24
Ik ben er heel vluchtig even overheen gejaagd.
Maak je gebruik van een eigen router of...? Want je gebruikt geen standaard ip adres. Dat is verder geen probleem, maar de leasetijd staat wel heel erg kort.
Om te beginnen zou ik de leasetijd eens op minimaal 1 dag zetten, dus 24 uur. Als er geen speciale reden is om hem zo kort te zetten zou je hem ook op 7 dagen kunnen zetten, dat is een vrij standaard instelling. En dan eens kijken of het probleem zich nog voor doet.
Straks zal ik nog eens kijken voor aanvullende zaken. Het logje is ook niet zoals wij dat adviseren maar dat komt nog wel.
In elk geval kun je eens kijken of er al verbetering is met het veranderen van die leasetijd.
gerrieger
OS: windows10
AV: norton
za 17 nov, 2018 20:57:16
Dank voor je snelle bericht. Super.
Geen eigen router,
WiFi-modem F@aST 3890v3.
Het lukt mij niet instellingsmogelijkheid voor leasetijd te vinden.
Bvd, Ger
Black Tiger
OS: Win7/Linux
AM: Malware Bytes
zo 18 nov, 2018 00:18:19
Hallo Ger.
Oei dat maakt het wat moeilijker, want deze modems zijn mij ook niet bekend.
Ik ben even in de handleiding gaan snuffelen en daar staat het volgende:
Start je internetbrowser en voer in de adresbalk het volgende in:
http://192.168.11.1.
Druk op Enter.
Vul bij “Username” in: beheer
Vul bij “Password” het Admin password in dat op het modem staat
Klik op “Login” of druk op Enter
Misschien heb je dit al gedaan. Zo niet dan zou je op deze manier kunnen inloggen en dan eens rondsnuffelen bij de LAN instellingen. Ergens zou DHCP en het bereik moeten staan met een ip adressenreeks wat begint met 192.168.11.xx. Daar zou ook ergens "lease time" of "leased time" moeten staan.
Hopelijk hebben ze dat er niet uitgesloopt met de standaard firmware.
Je schrijft dat heel regelmatig de verbinding verbroken wordt. Heb je een idee hoe regelmatig, hoe vaak ongeveer?
Heb je ook al het vinkje weggehaald in apparatenbeheer bij de eigenschappen van de netwerkkaart, bij energiebeheer, dat het apparaat uitgeschakeld mag worden om energie te besparen (mag dus niet aangevinkt zijn)?
Groet, Richard.
