Malwarebytes 3.1 is beschikbaar
Malwarebytes 3.1 is sinds gisteren te downloaden, in deze programma-update is vooral de stabiliteit aangepakt. Er waren immers nogal wat problemen na de lancering van versie 3.0. Ook bevat Malwarebytes 3.1 een nieuwe beschermingslaag. Middels de module 'machine learning based anomaly detection' kan het ook zonder definities verdachte afwijkingen detecteren. Ook heeft de gratis versie nu de optie om maandelijks een automatische scan in te plannen.
Download Malwarebytes 3.1: https://downloads.malwarebytes.com/file/mb3
Performance/protective capability
  • Multiple enhancements result in reduction of memory usage
  • Faster load time and responsiveness of third-party applications
  • Improved performance of Web Protection
  • Faster Malwarebytes 3 program startup time and responsiveness of user interface
  • New detection and protection layer with machine learning based anomaly detection (to be deployed gradually even if it shows “enabled” under Settings)
  • Improved Self-Protection by requiring escalated privileges to disable protections or deactivate a license
  • Enhanced malware protection techniques and remediation capabilities
  • Added an automatic monthly scheduled scan in Free mode
Usability
  • Added ability to control the priority of manual scans on the system
  • Added setting to turn off ‘Real-Time Protection turned off’ notifications when protection was specifically disabled by the user
  • Added ability to exclude the last website blocked by Web Protection via the tray menu
  • Fixed several defects related to configuring Custom Scans, including selecting child folders and fixing issues with touch screens
  • Fixed problem where a right-click context scan appeared broken after scheduled scan due to misleading "Cannot start a scan while another one is in progress" message
  • Fixed issue where you could not add or edit a scheduled scan in Spanish and some other languages
  • Fixed issue where scan could appear stuck on Heuristics Analysis when it had actually completed successfully
  • Fixed issue where Self-Protection setting would fail to toggle correctly after an upgrade
Stability/issues fixed
  • Fixed several crashes in the Web Protection module
  • Fixed issue where Ransomware Protection would be stuck in ‘Starting’ state after a reboot
  • Fixed a conflict with Norton that caused web pages not to load and plug-ins to crash in Chrome
  • Fixed issue with WMI protection technique in Exploit Protection that could cause Office applications to crash
  • Fixed several crashes related to the service and tray
  • Fixed security vulnerabilities that could be chained together to perform local privilege escalation
  • Fixed many other miscellaneous defects and user interface improvements
